Earlier, I commented that i felt as though I was
"tripping on the risers heading up a downward escalator."Well, I definitely skinned my shins on it this morning.
I was running a compression check. I had the spark plugs out in order to save the battery and wear-n-tear on the starter.
Now normally when I have the plugs out, I put the boots back in place in order to prevent anything from falling into the cylinders.
I started with the "1" hole, and then jumped to the "4", the "3" and lastly the "2".
I had nothing in my hand except the compression checker.
compcheck by
Chris ConradNote the arrow pointing to the plastic/rubber button extender for the Schrader valve. After checking # "2", I went to relieve the pressure and noticed that it was missing.
gauge by
Chris ConradNope - wasn't on the floor - wasn't in the catch basin under the motor - wasn't inconveniently lodged in the nest of wires that are the EFI/Ignition bundles.
No - it was wedged between the exhaust valve and the seat of the 2nd exhaust valve in the "1" hole - further compressed and wedged by the piston crashing into it.
pos by
Chris ConradWith the artistry and acumen of a dentist and an accompanying dental hygienist, Mark was able to fish it out through the exhaust while I was able to blow compressed air through the sparkplug hole.
A cylinder that was giving us ~200 psi was now barely giving us 150. A double check of the lash indicated a bent valve.
Fortunately, when Mark did the flow work on the head, lo these many moons ago, he kept a spare set of valves in reserve.
head by
Chris ConradThe head is off.
There's simply nobody to blame but myself. I KNOW BETTER than to leave holes open like that. I got in a hurry to start tweaking up the dyno numbers, and that turned around and bit me solidly in the toush.
I've always shared the good, the bad, and the ugly on this build. Both successes and problems have been witnessed here, and being a human project, one should accept human-related downfalls.
I've usually been able to forgive myself on the stupid stuff - but this one has just about taken it all out of me.
Let's see how it comes back together. Can't do anything until Monday, anyway. I'll keep everyone posted.
