More progress this weekend. Got the new rear-end cover installed and the differential filled with new AMSOIL 75w-90 Severe Gear. Nice piece. Probably not a necessary upgrade, but definitely falls into the cheap insurance side of the upgrade list. Also was able to finish the final trimming on my front air dam and fabricate a bracket to mount the relays for my oil cooler, trans cooler and engine cooler fans. I finished building the AN lines to my oil cooler thermostat and my main fuel line as well. Waiting on a couple fittings to finish building the AN lines to my trans cooler thermostat, which should be here and done this weekend. Only thing I have left after the trans cooler lines is to build my throttle cable and wire the relays for my fans and that should get me to the point where she is ready to get blown apart again so I can work on the motor, re-build the transmission, get the firewall sealed, mount the steering column and get going on body work and finishing the interior.
