Been awhile since I have updated on progress...just haven't had a chance to recently. Been super busy over the last couple months and have made a bunch of progress. The bed is back on the truck, which now includes the installed fuel cell and battery. My master disconnect switch is installed in the lower right side of the rear bumper and everything that is wired so far in the truck is wired through it. I have also got my fuel pump, water pump, ignition, and the switches and gauges that I have currently installed (waiting on more) wired. Inside the cab I have built my own dashboard and center console to house all of my gauges, switches and shifter. They aren't what I would call pretty, but, it was my first time working with fiberglass, and I at least now have a mold I can use in the future to improve on. Moving to the front of the truck, I was able to finish the manual brake conversion (first time building brake lines as well--yikes, haha) with upgraded rotors, pads and an aftermarket proportioning valve. Front sheet metal is back on the truck as well now too. Still waiting on my front end pieces to make it a 97 S-10 again, but, in the interim I can focus on mounting and plumbing/wiring my cooling system and fans, to include my transmission and oil coolers/fans. Looks like the next piece I will be stuck on will be an intake manifold. Everywhere I can find is at least a month out on single plane carb intakes for LS cathedral port heads. Maybe longer. Hopefully I can find one before then, but, I can always get started with mounting and modifying the current hood I have if not. I have a homemade version of a cowl hood in my mind (always liked cowl hoods) for it. Cheaper than buying an aftermarket one...guess we'll see how it turns out.
