Steve has it right.... regardless of the rule you are looking at... you want to stay inside the protective cage. You did not mention how fast you go, speed determines requirements... all those are minimums... so if you are required a net or arm restraints, you could do both... it's your arms... and legsIf you don't have lower cage bars that keep your legs in then you need a door net... can your legs come out?So all the answers are correct... for any LSR org... safety is what's driving the rules... your safety
