I?m doing some theoretical bench racing if anyone wants to jump in:
So first off, I?m talking about 1000cc classic modified. 160mph or so potential depending on aero/non and fuel type.
I?ve read and seen several examples of far faster sportbikes running swingarms with significant added weight for traction. One with 73lbs of lead shot, and similar weights of various forms.
Most of these high powered sportbikes are running wide rear tires. This presumably increases the, sorry for the incorrect terminology, float effect of the rear tire from the air pressure exerted from the extra tire width beyond the contact patch at high speeds.
Let?s say I?d be running a 130 series rear tire on a 3.5/18 rim. The aero geek in me says that if I can extend the wheelbase by nearly 6? to the Modified limit, I?d do it all in the swingarm and have the rider position as fwd as possible in the racers tuck position to maximize the length of aero fairing behind the rider for partial streamlining. It?s often said that the aero behind the rider is more important than the aero in front of the rider.
But this moves rider weight away from the rear tire. I imagine it?s safer to keep the rider?s butt near the rear tire for traction over the potential aero advantage?
Could a weighted swingarm make up that loss in rider weight over the rear tire and improve overall front/rear weight bias?
Increasing overall weight doesn?t seem to be of much concern. Aero, traction, and HP should by far be more important considering the extra weight is more a function of acceleration rather that top speed. Slow acceleration is needed regardless on the salt because of limited traction anyway.
Thoughts?
Thanks in advance
George
