To me the nose is not going to work. Looks like it would split a lot of air under the car... Narrowing the sides will split the air around not above and below. Nish streamliner showed this when they changed the nose. The sharp point needs to be more rounded...
Now, to clarify... I am not an aero guy... so that is just my opinion...
Stainless, thanks for the suggestions. Maybe if I explain my thinking on this would help me learn more.
DISCLAIMER: IM NOT A AERO GUY EITHER. I HAVE NO FORMAL SCHOOLING ON THE SUBJECT. ALL MY THOUGHTS COME FROM GUT FEELINGS AND WHATEVER THE PEANUT BUTTER CUPS TELL ME TO THINK
The nose comes to a sharp points My thought is that is the air's 1st contact point on the body. Im talking about the very first point. And since its very small, that actual point would create the least amount of pressure in front of the body. The pressure points would start within the body's boundaries. I actual DONT want the sweep into the belly pan. I want a tunnel. But if I cant have one, and Im forced to run a belly pan, why not keep the transition as smooth as possible instead of a more blunt radius at the nose? Wouldnt it help keep the air attached sooner to the body than a more blunt radius? Im sure the air will seperate under the car regardless but my thought is the blunt radius would make that issue worse.
The height from the point to the belly pan is 3" . Aside from the aero, I felt that was just enough to keep the nose from digging into the salt like a lawn dart if the front tires let go. I would rather not create any high pressure areas transitioning under the body but its unavoidable. Volume under the body is 15%
My thoughts is a tunnel would create the least amount of pressure, if the entrance and exit geometry was exactly the same. Again, the peanut butter cups is telling me that.
The fenders taper is 50% of the body's width. I feel this would create the smallest width of high pressure air, below the centerline of the wheels Again, I dont know, gut feeling and peanut butter cups.
Thanks.
