French, my understanding is the pistons are "matched" to the combustion chambers then "relieved" to the appropriate static compression ratio. As to the effective compression ratio, that is a calculated number based off of static compression then adjusted for relative boost. The Hammer pistons are designed for turbo applications with lowered ring heights, ceramic crown coatings, Teflon skirts, etc. If the basically stock pistons lived for as long as they did under boost/Bonneville conditions, I feel fairly certain these new one should too. YMMV.
