Author Topic: New Bike for 2021  (Read 6708 times)
Offline mc2032
  • Reliability and performance are highly overrated.
New Bike for 2021
« on: November 22, 2020, 02:02:34 PM »
New bike build diary.  1032 bike has pretty much found it's limits (174.343 mph) and i cannot complain so it is being semi retired (if we don't get the new bike done, we have this one).  New bike/motor will be purpose built, with the specific purpose of going faster.  New top end arrived from Idaho (Hammer Performance).  CNC ported heads, beehive springs, big valves, corrected cylinder head chambers all designed for a little higher rev limit.  Heavy duty rod assembly (S&S) (rods, center pin, bearings, races) is here as well.  I need to pull the motor out of bike no. 2 and start the teardown, see if there are as many "surprises" on the inside as there were on the outside, lets hope not.  Chassis design to commence possibly next weekend to get the bike fully into A Bike configuration.  The one picture has a set of stock valves to compare sizes with the new valves.
« Last Edit: November 22, 2020, 04:17:31 PM by mc2032 »
Offline mc2032
Re: New Bike for 2021
« Reply #1 on: November 22, 2020, 02:03:33 PM »
More pictures
« Last Edit: November 22, 2020, 02:06:38 PM by mc2032 »
« Reply #2 on: November 22, 2020, 02:28:37 PM »
Got any pics of the high performance rods S&S sent... hopefully after they are on the inside you will never get to take their picture again  :?
Offline donpearsall
    • http://soundappraisal.com
« Reply #3 on: November 22, 2020, 03:22:15 PM »
Thanks for starting a build diary. I will be watching for sure. Do you have a specific class record you are going after? You mentioned S&S so I am assuming the motor is some sort of V-twin like an HD. Good luck!
Offline mc2032
« Reply #4 on: November 22, 2020, 04:15:56 PM »
Will be staying in 1350 APS-PBG and/or F.  Engine is a '94 Sportster.  Here are the S&S heavy duty rods, and they are just as pretty in person.  A shame to bury them inside a set of cases, but then again i don't want to put a view port in the cases  just to look at them.
Offline Sporty Dan
« Reply #5 on: November 26, 2020, 10:54:15 AM »
Those heads look good! What are you looking for as max rpm's?
Be sure to keep us updated on the progress.
Offline 07R1LSR
« Reply #6 on: November 26, 2020, 12:13:54 PM »
Mc  just saw your post over on chopcult...congrats on your reccords at WF
Im building a chop right now and going with hammer performance 1250 kit for my little 883.
Offline mc2032
« Reply #7 on: November 26, 2020, 03:34:25 PM »
You will not be disappointed with getting "Hammered".  Keep us posted.
Offline thefrenchowl
« Reply #8 on: November 27, 2020, 05:34:07 PM »
Hi,
Is it me eyes or is the rear forked rod body not in line with the rod axis?
If it is, what's the /reason/theory behind the offset?
Subscribed anyway!!!
Patrick
Offline Dakin Engineering
« Reply #9 on: November 27, 2020, 05:57:55 PM »
Let's see the pistons that match those beautiful heads!
Sam
Turbo Sportsters since '97
Offline konon
« Reply #10 on: November 28, 2020, 11:08:32 AM »
Think it's the machined area that makes the rod look offset.
Sherman racing  M/PG 750
Offline mc2032
« Reply #11 on: November 28, 2020, 11:31:56 AM »
I was going to be funny and say they "pre-bent" them to save me some time but i think they are offset for clearance.  These are heavy duty and somewhat larger than stock.  To clear each other, I think they are designed this way.  I have tried googling it (no joy) so may reach out to the manufacturer for info.  I did see this offset done to rods in a Hot Rod - Engine Master Challenge magazine article.
Motor is out and leaking on the shop floor (2-1/2 quarts in, approx 7 out it's a harley thing).  Tried the old drag bike motor drop gravity assist (pull the bike outside onto the grass and lay it over then pick up the frame up off the motor) but rear rocker box was too close to the back bone.  So, back on two wheels, some disassembly and a cherry picker later I need to continue pulling spare parts off.  Maybe some pictures to follow.
Offline mc2032
« Reply #12 on: November 28, 2020, 09:56:23 PM »
Who would have thought changing the oil on this bike would be so hard!  It almost feels like rifle season and I bagged a zero pointer.  Front end picture of the chassis today.  It should/will look different.
Offline mc2032
« Reply #13 on: November 29, 2020, 05:14:21 PM »
Engine is field dressed ready for new rods and a balanced crankshaft/flywheels.  Should be able to get this to the shop sometime this week.  Also, an example of the fine craftsmanship exhibited by the previous owner.  Strip the Torx, drill part way then quit.  Leave it for the next guy has been his M.O. so far.  These should be the last of them, I hope.
« Reply #14 on: November 30, 2020, 01:15:44 AM »
There were a bunch of Torx bolts on my Triumph that Triumph that liked to strip.  They were replaced with hex bolts and the problem was solved.
