Are you thinking if you weld it to the sheetmetal it will be strong enough? The idea behind the 1/4 inch pads is it gives you something to weld to and the big sandwich area will be harder to pull/push out...
Of course if you think there is enough structure there to weld to you can take lots of pictures, present engineering data and try to convince the tech chair that you have it covered....
