Interesting read concerning the number of gears to go fast. If not always, at least for a time, the Hoffman liner ran TF 2-speed with converter. A couple of things about the 5-speed (we run a g-force), that 300 rpm split going into 4th and then again into 5th sure does sound sweet.
The 5 speed would give you a definite advantage over the 4 speed in having two really small spits between 3rd and 4th and 4th and 5th. Something that could be advantages to a really fast car like yours that is trying to accelerate to high speeds in the distance available. I would like one also, but out of our budget now and probably not needed for a 250 mph car.
Drag race dog type trans does not necessarily pop out of gear when you back off the throttle. We use a air solenoids on the shifter and when you get back on the power it is still in gear, no problems.
I imagine this is in response to my comment about transmissions setup for the drags on that page.
You do not want the "drag" ones. They are designed to pop out of gear as soon as you let off the power so they can slam them into the next gear on the drag strip.
Yes not all drag transmissions are setup like this, but some are and I just wanted to let someone know that might be buying a used one to make sure they don't end up with one of these (no fun driving at over 200 and having to hold the transmission in gear with one hand as you get in and out of the throttle
). When I talked to Jerico they said they could make one for LSR and would still work good at the drags, just not quite as good as one that was optimized for the drags. We have looked into this since Hooley drag races and with a different gear set (about $1300) he could do both with one transmission.
We also run a Casales-type overrunning sprag on the input shaft to the quick change.
Where can I find out more about this application???....and thanks for the other input. Good stuff there.
c ya,
