During Bonneville Speed Week 2020 we celebrated a new class record on Thursday morning with an official speed of 218 mph driven by Roger Hickey. We ran the car as hard as possible before losing power during both runs, a common occurrence on Bonneville?s long course. In the pursuit of speed, the team tried utilizing a longer more aggressive pre-chill of the drive components and a different starting technique with lighter throttle inputs. We were able to just scratch out another 11 mph before losing power again. In Roger?s absence, the car was piloted by a previous electric land speed record holder, Jim Hoogerhyde. We didn?t limit either driver?s power. We wish it was that easy! Hot conditions and Bonneville were the factors that limited our speed. Land speed racing is tough. We will be back to try again. Stay tuned for our data dump when we return to the shop. In the meantime, celebrate Roger?s record and inclusion into the 200 mph club. Celebrate speed and always try to go faster.....
Roger?s top speed was over 225 mph during a licensing run.
The car never shut off except one time when the 12v battery died......it would just get to 221 and slowly go slower. I drove the car off the track every run as to not cause the next racer anymore time waiting in line.Either way it was 50% my car and I knew nothing of this horrible decietful plan. Why was my name and companies name removed from MY BODY?
Quote from: Saltfever on August 15, 2020, 04:45:41 AMMy heartfelt best wishes go out for Ralph and his loved ones and I wish him a speedy and, most importantly, a complete recovery.However, Jimmy I don't consider the current discussion trivial BS. Calling another LSR team "Evil" based on ones complete misunderstanding begs to be clarified. And it doesn't serve the complainer well continuing on in ignorance. I am still confused about post #177 by Wickedwagens just as others have stated. Hopefully, I can give a factual example that simplifies the issue.."Evil" is a pretty strong word. There must be some bad bad blood there. Or the TEAM really didn't think all that much of him after the FACT
Speedweek update 2020. Im happy to report once again the flathead Ford powered Rons Hobby Shop Special {aka the Mistress wife's name for car} once again set a record. We had a lot of issues with the intake my son and I fabricated a long time ago causing a drop in boost by mile number 2 we used JB weld epoxy and blue Permitex silicone sealer to help seal things up the best we could. Doing this helped give us a strong 190 qualifying run when prior to that we were stuck in the 180's. Data still showed we were loosing boost mid run on the qualifier so we decided to speed the blower up a bit adding a couple more pounds of boost which in theory would help give us a top end push even with the loss of boost after mile two. All went well until the blower belt decided it was time to retire! However the speed by mile three was fast enough to get back in impound and the record. The salt conditions were outstanding I feel even better than the surface in 2018. We all would like to thank the entire SCTA crew for putting on the event. The efforts put forth by the board to even pull off the event Im sure was overwhelming those of us who had the opportunity to run greatly appreciate everything. Since we began running at Speedweek in 2016 we have now set six records. Its a long drive home and we must now quarantine but it was all worth it for sure. Now were getting ready to run at the LTA event next month in Maine our record setting ARDUN which has been sitting since 2017 is going back in the car time to run in the 200 range again. Ronnieroadster
Any news on Ralph? JL222
Quote from: ronnieroadster on August 15, 2020, 02:55:23 PM Speedweek update 2020. Im happy to report once again the flathead Ford powered Rons Hobby Shop Special {aka the Mistress wife's name for car} once again set a record. We had a lot of issues with the intake my son and I fabricated a long time ago causing a drop in boost by mile number 2 we used JB weld epoxy and blue Permitex silicone sealer to help seal things up the best we could. Doing this helped give us a strong 190 qualifying run when prior to that we were stuck in the 180's. Data still showed we were loosing boost mid run on the qualifier so we decided to speed the blower up a bit adding a couple more pounds of boost which in theory would help give us a top end push even with the loss of boost after mile two. All went well until the blower belt decided it was time to retire! However the speed by mile three was fast enough to get back in impound and the record. The salt conditions were outstanding I feel even better than the surface in 2018. We all would like to thank the entire SCTA crew for putting on the event. The efforts put forth by the board to even pull off the event Im sure was overwhelming those of us who had the opportunity to run greatly appreciate everything. Since we began running at Speedweek in 2016 we have now set six records. Its a long drive home and we must now quarantine but it was all worth it for sure. Now were getting ready to run at the LTA event next month in Maine our record setting ARDUN which has been sitting since 2017 is going back in the car time to run in the 200 range again. Ronnieroadstercongratulations Ronnie and your whole crew, I believe you guys where the only flathead powered car to set a record in 2020!
