Well you are not changing the venturi size... that is determined at the throttle plate.
This from the AMA rules
1. Production (P)
a. Use the same engines (gasoline only) originally installed
in the specific motorcycle frame at the time of production
and ensure it meets the definition set in the ?P? frame
class (See 3.11D). Original equipment (OEM) shall
include cylinders, cases (crankcases), heads, and
carburation or throttle body (stock venturi size), kickstarter or electric starter. Displacement determines the
class. OEM displacement specifications must remain
stock.
b. GASOLINE ONLY
3. Production, Vintage (PV)
a. Same as 3.11L.1 but with a production date prior to 1956.
b. Allowable overbore in this class is + .050- inches over
OEM standard bore to remain in displacement class.
4. Production, Classic (PC)
a. Same as 3.11L.1 but with a production date prior to 1981.
But you could put a .050 bore on the stock size and remain in class...
Just saying...
