Just an update:
I talked to Bob Stroud on the phone last week just before I started home. He had just seen the video of the spin (probably after Stainless sent it to him, I'm guessing).
He doesn't recommend us doing anything different with the chute. He feels a bigger one would hit too hard on normal runs. He did mention the possibility of a second bigger one, but then you run into the problems that Glen mentioned above. So I think Hooley is going to stay with what he has.
As mentioned above the bar (roll bar tubing) that the chute attaches to was bent to the right at about the point of the arrow in the picture or a little closer to the receiver it goes into. It was bent about 45 degrees. Up to this point we have assumed that the car spinning ran over the chute lines and bent the bar. I no longer believe that is what happened. When the car started to spin the back went to the left (west) and Hooley got the chute out in less than 2 sec. from the start of the spin. So about the time the chute hit the ends of the lines the car was about 45 degrees to the track. I think it was the initial opening of the chute and that impact that bent the chute attach bar 45 degrees to the right. Remember that the car was going 223 mph when the chute blossomed, so that would be quite a pull on that bar.
For next year the bar will be modified and will be triangulated. If you have a car or you are building one you might want to look at your chute attach point and visualize the forces on it if the chute deploys and the car is not going straight.
I have looked at this video (
http://www.youtube.com/watch?v=eixUJA-scBU&mode=related&search= ) a number of times as at the 3 min 10 sec. mark it has the end of Hooley's spin. Looking at the chute lines next to the car where they are wrapped in white material to me it looks like they never go under the wheels, but my monitor is not great, so if someone sees something else please let me know.
The car does appear to start to lift at the end of the last spin in the video to me, but watching the video from the back of the car the horizon never seems to tilt. Also just after that the chute starts to collapse and drop towards the ground. This is when I first though the car ran over the chute, but now I think the car was going so slow at this point that as the car swung back towards the chute the line just started to go slack.
I got the rest of the video from the other cameras from John when I was in Missouri and there is some neat stuff there. We have the view out the front of the car during the spin and also a view of Hooley getting the chute out and sawing on the steering wheel during the spin and the rescue crew arriving. It is nice having those guys out there and knowing how quick they are, thanks guys.
c ya,
