The closer the ratio you can get for the final gearshift and your projected
speed the easier it will be.
You won't ever have a power saving direct drive anyway and will always
be through a gear set.
Most often in a street trans the last gear is an overdrive and many times
you can't pull the power back up when the demands are the greatest and
the drop with the shift is the most.
Look at all the ratios and find the closest highest gear and sprocket to use that.
You will be geared pretty tall at the start but you can still take it easy on the clutch for the start.
You don't need a drag race start at Bonneville.
For example, I had a six speed -2 smoke and chose to use 3rd to 4th for
the final change and didn't use 5th or 6th at all.
I changed sprocket to the required ratio and was on my way.
The next class higher motor size had different RPM demands and with the
same sprocket ratio would pull the 4th to 5th change and it had the
increased power at a lower RPM to pull it.
All of that with the same bottom end.
