We were tuning E85, 10K rpm... looks great, 32 lbs of boost was what I asked for in boost control... yep... then the motor burbled... Ross said there was a small fire... and blue smoke puffed out the pipes. The center section of the turbo took a subaru.... no clue what happened... the oil looks good.... except for the crap what choked up out of the turbo into the scavenge pump... a ball bearing and some other stuff stopped the scavenge pump from pushing the contaminated oil into the motor.... and the oil and sparkles that choked up into the intercooler... luckily no oil at the output of the intercooler or the hat.
Clean up is ongoing... the only things I have left are the intercooler and pulling the oil pan to see what the .010" of oil in the bottom of it looks like.
The new turbo center and compressor show up tomorrow by noon according to FedEx... The old parts will be headed to Garrett for analysis... too bad that answer won't be back before we head to the salt. The new turbo had almost 30 minutes of time on it... about 50% just running and the remainder at full throttle, first with the 3/4 then with the 1 liter.
The turbo supplier asked if I had water cooling hooked up... well Garrett said it would last longer with water cooling... I wasn't thinking they were talking forever vs minutes....
But in an abundance of caution I started figuring out how to water cool the turbo while I wait for the new parts... more pounds of subaru in my 5 pound sack....
Just like every other Bonneville... the thrash is on....
