Intakes do look like they are retaining heat rather than transferring it into the seat/head...🤔 Maybe widen the margins on the valves and seats? How are the spring pressures? And, Is there any air flow past the head?
Well I think they have plenty of seat width, Deni is not a RCH wide seat fan... he usually does about a 1/16 wide seat area... But it's not like they spend a lot of time on the seat at 11-12K RPM.
The springs are the 65lb heavy duty aftermarket ones... stock are 45... they all checked good before I installed them after the head was repaired... maybe 70 miles ago.
And no, there is probably no air moving around the head... water temp runs up to 195
. . . OR . . .
are you seeing enough oil flow to that side of the head to draw away the heat?
If oil is collecting and raining in on the exhaust side, might it be pooling on the exhaust side at the expense of the intake side?
Well there seems to be oil collected in all the bucket wells... but I've only run one of these engines with the valve cover off... oil slings 2 feet in every direction
Do you have O2 sensors in each of the exhaust pipes? Just seems there may be a different A/F ratio in the cylinders shown to the right compared to those on the left.
Tom, I do not have EGT or O2 in individual runners ahead of the turbo...
I wish I'd taken pictures of the head when it was off to lap a several valves after we ran E85, but I don't remember anything odd. But I know it ran fairly lean since the injectors maxed out at about 9500 RPM....
Here's a blow up of the valves 4 and 3 (I hope)
