The rulebook deserves rereading before you cite gasoline as being
forbidden in the Fuel class.
Yes and no on gas being allowed in the fuel class. "In fuel classes any approved liquid fuel may be used. Examples of approved fuels are: alcohol, hydrogen, nitro methane blends, nitrous oxide, and unapproved gasoline."
"the average Dielectric Constant for the hydrocarbons which compromise gasoline is 2.025. This is defined as a reading of zero (0) with the SCTA fuel Check Meter. The maximum acceptable meter reading is +/- 5, with zero (0) as the reference reading. A gasoline that has a greater reading than 2.3 will cause the meter reading to be outside this range."
So how I read the rules is: gas that is legal for the gas class, cannot be run in the fuel class, but gas that is not legal for the gas class can be run in the fuel class. So if someone jumps from a gas class to a fuel class and runs the exact same gas in the motor, I think that would be a violation of the rules, since they are running an approved gas.
