Author Topic: Schimmer and Son "I" class fuel lakester:  (Read 161856 times)
Offline STICK777
Re: Schimmer and Son "I" class fuel lakester:
« Reply #255 on: August 13, 2019, 10:10:59 AM »
And from there you have all the options... red snorkel or actually any color you fancy... or a belly stripe...
Cheers!
« Reply #256 on: August 13, 2019, 10:52:23 AM »
That is a big accomplishment to get there with that nice car.  Go fast.
Offline STICK777
« Reply #257 on: August 18, 2019, 04:49:16 AM »
Why can't I see my own attachments anymore?  :-(
« Reply #258 on: August 18, 2019, 10:04:08 AM »
Something's going on. I can't see most of the avatars either.
Offline bobc
    • South Mt. Web Design
« Reply #259 on: August 18, 2019, 08:28:28 PM »
The attachments should be there now.  If there's an avatar missing, let me know who or where, ok?
BtWE
Web Elf
« Reply #260 on: August 18, 2019, 09:51:35 PM »
It looks like you've had a successful day of hunting and restoration.  :cheers: :cheers: :cheers:
Offline STICK777
« Reply #261 on: August 19, 2019, 01:34:40 AM »
Yep, all my attachments are back! Thanks!  :cheers:
« Reply #262 on: August 20, 2019, 05:53:42 PM »
STICK777,
Thanks for the paint job concept, now to just make it happen. looks great!
Offline STICK777
« Reply #263 on: August 21, 2019, 02:26:20 AM »
My pleasure...  :-)
-Oliver
« Reply #264 on: September 10, 2019, 07:17:14 PM »
After the disaster of Speed Week, ( I have never spent so much money to be so miserable!) Duke and I have gotten everything ready to try the WOS. Looking for a good, smooth and dry course. We have repaired the burn damage and cleaned outall of the fire extinguisher dust, with Duke doing a great job of wiring and he has the AEM data acquisition system up and running so we will know fuel mixture, fuel pressure and inlet plenum pressure. I have knocked up some aero fairing for the front axle and I hope we can get in as many runs as we did last year except about 50 mph faster!! Positive thought about NO RAIN!!! Be there early Thursday AM. Hope to see many of you there.
« Reply #265 on: September 10, 2019, 08:02:06 PM »
Rex, see you there. Hope I get to announce your record.
« Reply #266 on: September 11, 2019, 09:45:50 AM »
I hope you get to also  :clap :clap
Offline bearingburner
« Reply #267 on: September 11, 2019, 05:59:29 PM »
If you think you spent money and were miserable think how the people from the east coast
or further felt.
« Reply #268 on: September 17, 2019, 02:28:29 PM »
A quick report of our trip to the WOS meet. We ran our fastest ever speed, 195.75 but we were fighting an engine oil blow by problem on every run. We would get back to the pits and drain about a pint or more oil from our new catch tank and we would have a lot of oil that found its way into the bottom of the car. So the motor has a date with the guys at Engine Dynamics for a freshening and a look at what the case pressure problem might be. Duke also could not get into 6th gear so that is another item for John and Mike at ED. I was pretty sure that we needed less gear so we installed a 15 tooth primary sprocket in place of the 16 tooth sprocket and even just using the first 5 gears the 15 tooth would give us a 200+ number if we could get the motor to 12,000 in fifth. The run started well but Duke said the car had a strong pull to the right so he shut it off at the 2 1/2. We did go 185 at the 2 1/4 which was our best time for that clock. So it was pulling great.
Things that we did that worked well: MSD ignition: This modification worked really great, it never missed a beat and made starting so easy because of the great spark. It took a little work to get it to fit the engine but was really worth the effort.
AEM AQ-1 data logger: Duke wired in  the data logger and programmed his lap top to down load the data into. We only were looking at the  AFR from an 02 sensor in the exhaust, fuel pressure, and air box pressure. The 02 info was great, we could see the results of each jet change and now we are starting to log this data to give us information for future set ups. The fuel pressure info is going to require some additional analysis but good info to know. The air box pressure data was the only one that I was disappointed with , not because it was wrong but because it was showing that my air scoop was not doing its job! Even at almost 200 mph we were not seeing any additional inlet air pressure for the engine inlet. Back to the drawing board!!
We already have started out "things to do for next year" list and are starting our planning and design.
We had a great time!!!
Rex and Duke
« Reply #269 on: September 17, 2019, 11:57:27 PM »
Jeez Rex, I would have thought you'd been involved in motorsport long enough to know that most of the dates don't get past buying dinner  :laugh: :laugh: :laugh: :laugh: :laugh:
