Just curious regarding tips the old hands may have regarding planing for those occasions like this years WOS where you end up with water on the salt.
In this years case, I understand that max water depth in the pit area was around 1" or so. When we got to the end of the road the water just off the ramp was 5 -6 " deep but that seems to be the only deep water area from what I've heard so far.
Historically what is the deepest water level you folks are aware of on the salt flats proper due to wind blown water or rain storms?
My thinking is it takes a huge amount of water to increase the depth much over such a large surface area, so my guess is that during Speed Weeks, WOS or WF, the maximum water depth in the pit areas would be just a couple inches or so.
With that in mind, what precautions do people take when there is a chance that a wash out is possible. I recall seeing several pictures of cars on the salt on jack stands and such to wait out wind blown water.
Obviously picking up your gear at the end of the day will help, but for things you can't easily pick up and store on a trailer and such, how much "elevation" would you think a reasonable plan?
A set of pull on rubber boots (over shoes) in your car that you drive out to the salt, would obviously be on the list if you need to slosh around picking up your gear for a rain out.
Putting the car up on ramps or jack stands etc. would be good idea if you expect a brief rain episode. If there is a likelihood of a full rain out I suspect the plan of choice would be to run the car up on the trailer before you leave the pits for the night. Or if it was a high probability, even trailer the car off the salt.
Larry
