List,
I have had several people ask on how to add a image under your name like I have here. After researching I found I did not have this option selected in the setup files. Now it is so you too can add an image. Typical size needed should be 65X65.
And here are the instructions on how to do that.
1. First you must be logged in.
2. On the top right of screen you will see my profile. Select that link.
3. Edit profile.
4. Scroll down to Avatar Images.
5. You can select one of the default images for you can set a url path to the image to use.
6. At the bottom of the page make sure to select update profile.
Any problems please let me know.
Jonathan
