Use of the GPS is what I am typing about. This is a complex subject and there is much more to it than this.
Setting points with the GPS is dependent on the proper equipment, skill, and calibration. The end product is two points located on the salt. The big question is, are they within the allowed error tolerance? One can assume if the equipment and operation is adequate that the points are correctly placed. This is an unproven assumption.
Chaining or EDM are surface measurements. The crew proceeds from the first point to the second. They set that point. Then they measure back to the first. The difference between the two is closure. The closure needs to be within the allowed tolerance. One has been mentioned in a previous post. One problem is if the instrument is out of calibration. Then, using the same instrument to go both there and back gives good closure but the point is set at the wrong distance. We can go out with the EDM and come back with the chain. A consistent difference between the two instruments readings indicates a calibration problem. Or, the EDM can be checked across two points of known distance. This last is easier. We have two markers set in concrete in the parking lot and we know how far they are from each other. We check the EDM calibration every morning.
In summary, a GPS that is accurate enough to set points is pretty expensive and needs to be operated by a professional. There is no good way to check the closure unless the distance is measured by calibrated instruments. Heck, if the distance measurement tools are needed, they can be used to mark off the course and there is no need for the GPS.
