We went to the spring ECTA event. On the first run at about 3/4 of a mile the power went down smoothly like gently lifting off of the throttle. Looking over the data from the logger the engine went lean and the ECM shut the engine down. I was expecting this to happen, just not this soon. I have been running VP MS109 which contains MTBE as an oxygenator. Every component in my fuel system except the injectors was compatible with this fuel. With the injectors running at 90% duty cycle I knew they needed upgraded but I was putting it off until I decided on the next steps. Inspection of the plugs revealed no damage, the ECM shut the engine down before anything bad happened. I am thankful for that. I have decided to add a wet nitrous system because once I go down the nitromethane route the fuel system would not accommodate any other fuel which limits what I can do with the car. More to come on the nitrous as we hit the dyno with new Injector Dynamic 1,050cc injectors which are compatible with all fuel including nitromethane and MTBE.
