I'm with Brad on the little brain part.
To begin with, we're not talking spinning, yawing, losing traction, side wind, tractive force, torque, sidewalls or any thing other than cg /cp in a straight line. All that other stuff just muddies the water.
If I have enough wing at the rear and far enough back so that it lifts the front wheels off the ground at speed, (as some dragsters have done). It sounds like I'm supposed to believe that the cg of the moving car is still the same at speed with all the weight of the car plus all the downforce on the rear tires. You could theoretically could build a front motored rear wheel drive car that had 80/20 static front bias and with enough wing far enough back and enough speed, lift the front wheel off the ground.
. If you have a bar with a weight on one end and an equal weight in the middle and both weights sitting on two scales. If you apply down pressure to the free end of bar til the end weight is off the scales, the second scale will show the weight of both weights plus the weight of the bar, plus the weight of whatever downforce it took to lift the first weight.
With the logic that if a wing doesn't add or remove weight, an airplane while flying would have no weight whatsoever and therefore would not have or need a center of pressure. (good luck on that one)
YMMV
Ron
