....You don't think so. Explain how Top Fuel tires are flattened without added weight on chassis and how the CG hasn't changed dynamically....
This is my last response to a question such as this. Aero downforce flattens the tires and the CG of the car itself is in the same location relative to the car. If the car does a wheelstand then the CG goes to a new location in the universe along with the car.
You just keep coming back to aero forces on the car that for sure are there and I'm not disputing that but they don't change the CG. A NASCAR car should have what you are talking about with all the downforce built into the car and if you are correct it should keep the car from spinning once it loses traction but it doesn't.
I'm not saying you need to give up trying to gain traction, that would be foolish. We now have the CG ahead of the CP on Hooley's Stude and I"m convinced that was what kept it from going around in 2013. Now we can more or less leave the car alone and stop adding more weight since we can gain traction via the rear wing, using its size, profile and angle of attack. But while experimenting with that if we loose traction with the CG ahead of the CP that relationship will go a long ways towards keeping the car from spinning. It isn't just the spin that is dangerous, some cars once sideways tend to start flying. Long cars like streamlines also don't tend to spin very well as witnessed by the number that receive a lot of damage once sideways.
My remark about the blown gas/ blown fuel referenced that now with the development of turbos and in your case centrifugal blowers it isn't that hard to build any motor larger than an F motor that will put out over 1000 hp and a lot more. So with that kind of HP available a lot of the cars that can't have a wing and the vertical stabilizers that can really, really help with the CP part they can add both weight ahead of the rear axle for traction and weight further forward to move the CG forward.
I've already repeated myself to the point I'm even tired of hearing myself on this so people will just have to decide what they want to take from this thread. I'm not trying to convince you to change your car. If it is working for you stick with it.
