Wow! That was some crazy, seat puckering videos! I was never saying they all spin to the right (but since we're watching that video, how many went right?), I'm saying that particular issue can be fixed easily enough, so you can get farther at speed until your NEXT set of issues arises! If BOTH tires are planted EVENLY and spin, it's a crap shoot on which way it'll go. I still look at this as a really long drag strip and always will. Obviously, you can't launch the same way, but the car twisting and unloading the rear tires on a dragstrip at half track is very much relevant in THIS sport! The drag guys got tired of fighting it and have numerous fixes for that problem without adding weight. Adding lead to one side or another is just a band aid for the actual problem ( you'd need to change the spring rate AND revalve the shock for the weight difference on how the suspension reacts), plus the added weight slows the acceleration of the car. Fix the problem first with something as simple as an airbag and add weight when the car hits it's wall/air barrier and unloads the rear end (i.e. spun the tires at 170mph, added 200lbs and went to 190mph before they spun again) and go to the next thing.
