Author Topic: C4 Corvette AA/GMS Build  (Read 21845 times)
Offline Jesse9938
Re: C4 Corvette AA/GMS Build
« Reply #15 on: November 06, 2014, 06:45:19 PM »
Cont...
« Reply #16 on: November 07, 2014, 12:19:57 AM »
F A N T A S T I C  image sizes.
The better to see You my Dear.
Offline gray63
« Reply #17 on: November 07, 2014, 07:38:03 AM »
Have you checked your top rollbar above the drivers head.
I built my C4 Roadrace car with a similar top bar and my helmet was
in contact with the bar. My seat was sitting almost flush with the floor
and I am only 5" 10'
I had to remove the bar and move it out about 2 inches to clear
my helmet.
Dave
56 Corvette
# 3611 BGMS
« Reply #18 on: November 07, 2014, 12:26:34 PM »
Inspectors "like"  to see lower tubes connecting the four corner "posts" forming an upper and lower "halo"
Offline Jesse9938
« Reply #19 on: November 07, 2014, 02:24:46 PM »
Freud - I agree, much better to see!  Thank you!
Gray63 - Thank goodness I am only 5'8", because he had the upper bar totally straight at first and with the Halo seat 1.5" off the floor my helmet was almost touching that upper bar, so he took it back out and added that slight kick up.
     My biggest worry now is getting my fat butt into the car once the other bars are in place...LOL!
Sparky - Please, educate me more, I really appreciate any and all advice!  I am new to roll-cage construction and want to be sure I bring up your advice/recommendation to him, so I meet all the desired tech requirements and also so I am 'safe'.
Thank you,
Jesse
Offline Jesse9938
« Reply #20 on: November 07, 2014, 02:44:43 PM »
Redhotracing and lsrjunkie - Thanks for the info. I am hoping I will get the 2014 rulebook any day.
Leadfoot - I have 2.125" dia. Hooker Super Comps that I modified sightly to fit the chassis. Thanks.
Offline vwpsycho
    • Potter Bros Racing
« Reply #21 on: November 08, 2014, 10:12:14 PM »
When we built our Production VW Passat over the last 3 years, we were fortunate to hire the racecar fabrication services of (, to name two...) Brian Thomas and Tim McNees, both local here in Salt Lake City. Our car has passed Tech Inspection smoothly from its first Speedweek in 2012, and has given us confidence to safely exceed 200 mph at Bonneville dozens of times since... There are tons of build photos on our facebook page. https://www.facebook.com/PotterBrosRacing/photos_stream?tab=photos_albums
Hope that is useful!
Abe Potter
Salt Lake City
2571 G/PS Volkswagen Passat
Offline DND
« Reply #22 on: November 12, 2014, 03:42:33 AM »
Hi Jesse
Are you going to lift off the body to get to all the welds on your cage?
When checking your fit in the car be sure to have all your gear on as you will get bigger
Andy Welker used metal brackets and hose clamps to hold his cage in place , to be sure it all was right then welded it up
Very crafty idea, you might want to check out his tank build as he did one hell of a great build job
What kind of speed are you looking at in your class ?
Looking good, G Don
« Reply #23 on: November 12, 2014, 09:23:55 AM »
Just to piggy back on the last post a little, also have your required sfi roll cage padding in place when you do a fit check... the pad in commonly 3/4 inch thick... You do not want your helmet touching anything during a run.
Offline DND
« Reply #24 on: November 12, 2014, 10:14:03 AM »
Piggy back #2
Allow for some belt stretch too, not sure how much?
Since you are 5'8" maybe you can recline your seat for more room on top, that would be a good thing !!!
« Last Edit: November 12, 2014, 01:32:26 PM by DND »
Offline Jesse9938
« Reply #25 on: November 19, 2014, 05:52:57 AM »
A few more pictures of our progress!
Offline Jesse9938
« Reply #26 on: November 19, 2014, 05:53:23 AM »
Another...
Offline Jesse9938
« Reply #27 on: November 19, 2014, 05:54:20 AM »
Finishing welds after trial fitting....
« Reply #28 on: November 19, 2014, 05:17:15 PM »
Excellent fit on the tubes.
That wasn't easy for sure. :cheers: :cheers: :cheers:
Offline Jesse9938
« Reply #29 on: December 11, 2014, 10:08:29 PM »
Sorry for the long delay, Work has been very Crazy!  Thank you all!!!
