General stuff:
1. How long are you officially timed when running?
1 mile -- 2 to 3 on the short course and your choice if you qualify for the long course of 2-3 or 3-4 or 4-5. If you qualify for a record it has to be backed up in the same mile.
Do you have to maintain your speed through the entire 5 miles or is 1 timed mile enough to get your time officially recorded?
See #1
2. Do you have to qualify before officially running for a time?
If you run over the record then that counts as one of the 2 runs required to set a new record.
Do you have to qualify to run in the World Finals?
No
3. How does licensing work?
Read this:
http://purplesagetradingpost.com/sumner/hooley/hooley-2004.html4. Where can you camp with a motorhome?
At the "bend in the road or near it, not on the salt.
Is there a curfew on the salt?
yes, usually by 8pm
Can you set up shop in the pits and stay the night there?
No
5. What should I expect in tech?
They will make sure the car/bike meets safety requirements. (before you race).
What should I expect in tech if I set a record? (Are they going to completely tear me down?) What tools are needed, etc.?
see the rule book.
6. What should I bring for the race (obvoiusly shade, water, etc.)? I am looking for suggestions for things that you always wish you had brought but didn't think of.
There is a check list on here somewhere maybe someone has the link.
7. How many runs per day should I expect?
Speed Week for the first couple days only 1 to maybe 2 if you are first in line in the morning. Later in the week plenty of runs to blowup.
8. How long do you have between runs?
As long as the line. 4-5 hours the first day
9. Are you allowed to bring 4 wheelers ( ATV) for the wife and kids to spectate?
Yes, but not in the pits or race area.
10. Are you assigned a number ar can you chose your own number (Motorcycle number)?
You can ask for a number if it is availible (see rule book)
Technical stuff:
1. What is the average density altitude in early September?
Speed Week is in August and World Finals is Oct., other than that it can vary.
I know this is a loaded question; I am just wondering how much leeway I need to give myself with the engine map, timing etc. I live in Reno, NV, so I test a lot at what I think is similar altitude and conditions.
You might be at an advantage living there compared to someone back east or on the coast.
2. I plan to run a 2006 Suzuki GSXR 1000 with every modification I can think of, can I run Hayabusa throttle bodies and stay in the production class?
Probably not if they don't look exaclty like the ones on the 1000
If not, can I bore the stock throttle bodies?
I would think so, but I'm not a bike kind of guy
It is my understanding that as long as it looks identical externally it will be allowed?
That is what I also understand.
ideas?
No
3. I plan to run 1000cc P-P. I have been talking with Dan Wright at length about P-P and I have a clear understanding of what is needed. I do have some questions about other classes.
During the meet can I remove the fairings, add nitrous, and run in a modified fuel class, or change the wind screen and front fender and run in gas modified partial streamline? How do I go about tech, registration etc. when running 1 vehicle in multiple classes?
You pay more money to change classes and probably go back through tech.
4. What is the unlimited class?Why are they so much slower than the other classes?
Probably any size motor you want to run and maybe it is larger and punches a bigger hole in the air, maybe there is not the same speed equipment available, maybe I don't know.
5. My leathers have perforations in the crotch, behind the knees, and under the arms. Are these perforations going to be a problem?
Yes, do a search and see what to do about it. Basically I think you can have new leather sewn on over those areas.
6. Are the stock fuel lines sufficient to the rules if I install heat shileding over them?
got me.
7. Can I sleeve and reduce the bore size in a Suzuki Hayabusa to 1000 cc, run it on Nitro, in a GSXR 1000 frame with extended swingarm and long drag race tail in modified partial streamliner fuel?
Don't know
8. What should I expect with a 2006 GSXR 1000 running a legitimate 197HP at the wheels ( Motor only) at Bonneville? I don't want to get my hopes up, but it has gone 202mph on GPS in Reno, NV while testing ( slight tail wind and very steep down hill) just kidding. What should I expect with the same bike with an added 65HP of nitrous?
Expect to find the salt is harder than you expected and expect to find out as only you can by actually running.
9. How much is traction an issue with the above mentioned Motorcycle?
You will probably have to find out for you particular bike, but a lot have run 200 or more..
10. How wide is the course?
I'm guessing 100 yards.
11. Can I put any under 3 liter engine in a mototcycle and run it ?( 3 liter Judd V10 full race motor)
Maybe only in a streamliner, but I don't know for sure.
I have read the rule book repeatedly
Read it again and again and again and keep them all and have them at work, in the shop, in the john, etc.....
And like the good dr. F said if you can't get your b..t to one of the meets, especically as close as you live, then why even ask questions???
Hope to see you on the salt,
