At Bonneville, I have spun twice in a roadster and twice in the Pierson Coupe. I venture to say that all four times were because of stupidity!
The first time in the roadster, I had transmission trouble,was holding it in gear with my right hand and driving with my left. It got away from me. The second time it was skating around and I should have lifted, but didn't. With the coupe, the first time was on a wet course trying to qualify against a 205 record, hard on it w/nitrous working on the short course, the rear move to the right and I corrected...too much... and I just went along for the ride. The second time, shifting to neutral, I pulled it into reverse at 195 and got a couple of rotations. All of these could have bee en prevented with a bit more heads up driving. I would suggest that most of the spins are driver actuated.
My advice is to always be aware of the speed you are traveling and react accordingly. Driving fast is like being on ice...be careful when applying either brakes or steering.
As for parachutes...they can be a blessing or a curse. The second time I spun the roadster, my chute blossomed after the second rotation and ended the spin (I have five pictures of the spin that were given to me by Bob Mack). Another time, at the lakes with Grant Jones driving the roadster, the chute came out while the car was rotating and draped itself over the canopy. If it had caught air it could have been fatal. There were chute shrouds around the driver's neck. I found out in my car when it was getting too far out of control, when I reached for the chute, I also lifted a bit. The car straightened itself. Remember the throttle works both directions.
Tom, Redding CA 3216 D/FCC
