Author Topic: No Longer Need a GM 4 speed shifter with reverse lockout in Ohio Found One  (Read 2337 times)
Offline yarp
Was going over the tech inspection sheet and realized that my shifter button is hacked and disabled and won't pass tech at Wilmington. Does anyone have a used GM 4 speed shifter with reverse lockout in Ohio?
« Last Edit: April 19, 2014, 10:59:30 PM by Stainless1 »
Offline Ron Gibson
Re: Need a GM 4 speed shifter with reverse lockout in Ohio
« Reply #1 on: April 09, 2014, 10:06:02 AM »
If this is for LSR, just remove the reverse linkage. Tech won't argue with that. Can't drive under power except on course anyway.
Ron
Offline MIKE MATY
« Reply #2 on: April 09, 2014, 10:33:51 AM »
You should specify automatic, as gm manual 4 speeds are more common here.
ECTA 200MPH CLUB Maxton
A/FRS      205.531
D/FSS      159.427
ECTA 200MPH CLUB Ohio
A/FRS       208.530
2013 Hot Rod Top Speed Challenge Winner
Offline mike f
« Reply #3 on: April 12, 2014, 08:48:03 PM »
Hi Mike from MF.  I have a used Hurst comp. plus shifter complete.  Rods,levers,and mounting place. It is a standard set back and will fit a T10 or Munice trans.  will sell for 75.00.  Call me at 715-462-3817  Mike  Sell as is.
Offline Bob Drury
« Reply #4 on: April 13, 2014, 12:26:23 AM »
   and I have a Reverse Lockout for the above Hurst shifter.                   Bob
Bob Drury
« Reply #5 on: April 13, 2014, 01:34:27 PM »
I think he's still talking automatic.
Offline yarp
« Reply #6 on: April 15, 2014, 06:41:41 PM »
I was, I just received a TCI so I am no longer looking. Thank you everyone. Outstanding
