Author Topic: LSX / Supra classification  (Read 22305 times)
Offline yarp
« on: March 30, 2014, 03:07:54 PM »
I can't decide if it should be gas coupe and sedan or modified sports.
The car is completely original externally other than being lowered.
Seems like the engine swap forces me into modified sports???
appreciate any help.
Offline Speed Limit 1000
Re: LSX / Supra classification
« Reply #1 on: March 30, 2014, 03:53:21 PM »
If it had a back seat it is not a GT car. Only GT cars can move into modified sports.
Offline yarp
« Reply #2 on: March 30, 2014, 04:45:36 PM »
so the engine swap would make it gas coupe.
Offline 1leg
« Reply #3 on: March 30, 2014, 08:44:27 PM »
My understanding is that all supras came with rear seats, but i'm not an expert.
So it looks like gas coupe
Post some pictures! please
Jerry
SDRC Member since 2013
As iron sharpens iron, so one man sharpens another.
Psalm 27:17
Offline yarp
« Reply #4 on: April 01, 2014, 08:28:08 PM »
Except, its currently setup on E85.
I just found out that I have to bring my own E85 to Wilmington, and I was planning on driving the car there.
so gas coupe with a re-tune.
or
FGC on E85...though I don't see a fuel gas coupe class.
No pics yet. Ninja stealth mode and all. I don't even have a license yet and if I don't get the car sorted I might have to rookie up in a hyundai.  *shudders*
Offline dw230
« Reply #5 on: April 01, 2014, 09:47:01 PM »
There will not be a fuel "GAS" coupe class. The name of the class is GAS coupe, use the provided gas or be subjected to a gas check if you are using pump gas. E85 puts you into a "FUEL" class be it Fuel Altered(check other requirements) or Fuel Modified Sports if the body is deemed to be a sports car vrs. a sedan.
Good luck,
« Reply #6 on: April 01, 2014, 09:50:19 PM »
Get clarification from ECTA.
Offline yarp
« Reply #7 on: April 01, 2014, 09:53:59 PM »
Who at the ECTA should I ask for clarification?
« Reply #8 on: April 02, 2014, 12:33:04 AM »
Go into "Welcome" in the ECTA website and pick "contacts". There's an e-mail address there for rules questions.
Where are you really located? If you go into your profile and change your location to what it really is then it's quite likely that there's someone close that may be able to help you.
Offline Joe Timney
    • Delaware Chassis Works
« Reply #9 on: April 02, 2014, 06:35:18 AM »
Yarp,
To run in the ‘Gas Class’, you are allowed to run unlead, leaded or oxygenated gas. Nitro and alcohol require you to run in the ‘Fuel Class’.
Do you have a current rule book?
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
« Reply #10 on: April 02, 2014, 07:18:19 AM »
Yarp, you just got your answer from THE MAN at ECTA.
Joe, thanks for posting. It's really appreciated when someone with authority monitors this site and can give definitive answers.
Offline yarp
« Reply #11 on: April 02, 2014, 11:02:57 AM »
Yarp,
yes sir, 2014 rule book has no mention of E85 (perhaps because of the alcohol content?) , but talk around these forums says that puts me in the fuel class. I'm just trying to figure out which fuel class.
unblown fuel altered maybe?
Offline Gary Perkinson
« Reply #12 on: April 02, 2014, 12:09:15 PM »
[/quote]
I could be wrong, but depending on the displacement of the LSX engine, you would probably run in one of the following Fuel Coupe classes: AA/FC, A/FC, B/FC, or C/FC. The engine swap knocks you out of Production and puts you into the Coupe class (which is a level within the Modified category), but you need more modifications (e.g., a step pan, a large engine setback, or covered headlights and grille) to move into Altered. The use of E85 knocks you out of gas and into fuel. So you're basically a Gas Coupe that's not using gasoline, which makes you a Fuel Coupe...
Gary
LTA   G/BGALT Record (1 mile)     143.313
LTA   G/BGALT Record (1.5 mile)  148.321
LTA   F/PRO Record (1 mile)         114.668
Offline redhotracing
« Reply #13 on: April 02, 2014, 12:35:50 PM »
Gary
There isn't a /FC class, only /FCC (comp. coupe) which requires one of several major modifications to run.
/FALT or /FMS, depending on how the Supra is defined, would be the right classes for this car. For ECTA it
could also run /FRS if running a carb or /FSS if running EFI.
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Offline yarp
« Reply #14 on: April 02, 2014, 12:53:03 PM »
Sounds like if I just bring a roll of duct tape I can run /FALT
Cant do /FMS cause of the backseat is what I'm being told.
« Last Edit: April 02, 2014, 01:09:47 PM by yarp »
