what about the the tank body and the frame offered by www.rodnrace.com ? Are most lakesters designed for Bonneville suspended or are they rigid? I can see how both could have advantages.
Dwight
Hi Dwight, are you going to be able to make it to one of the meets this year as the others have suggested? I feel that is priority one right there. You will learn more in 3-5 days than you will searching the web for a year.
If you can't then if you go to this page:
http://purplesagetradingpost.com/sumner/bvillecar/bonneville-Index.html.....where you will find a link to my lakester construction and to Harv's lakester construction. On my pages near the beginning you can see what I think about the suspension deal.
More important though is further down that page you will find a link to a page with dozens of links to other cars under construction. You can also do searches on this site as a lot of the questions I'm sure you will have have been discussed. If you can't find an answer then ask.
I think after you look a little and decide what motor class you want to be in you will have a better idea if you think that tank will work for you (Hooley got the front for his stude from them).
I assume you realize to be in the 200 mph club you have to set a record over 200, not just run over 200. Personally I'm just shooting for "my 200 mph club" right now. As someone else mentioned this is a highly specialize class and there are not very many "soft" records in it anymore. Also if you just pick a soft class by the time you get your car done it might not be so soft anymore. I would look at cars and decide where you are most comfortable with motor wise and build wise.
One other thing to consider if you plan on running over 200 you will have an easy $3000-$4000 in safety equipment, so budget that in and take the rest of your budget and probably triple it.
If I can help at all let me know and as Jon said come on by my place and go to the salt with us we are right on the way for anyone driving from Texas (and there are 34 entries from Texas -- any of the rest of you coming this way???).
c ya, Sum
