Author Topic: Building my first Streamliner  (Read 161342 times)
Re: Building my first Streamliner
« Reply #315 on: February 20, 2022, 02:30:24 PM »
Me too Brad! Give me a call some time.
Offline kustombrad
    • Project No Bucks '49
« Reply #316 on: March 08, 2022, 09:50:29 PM »
Good evening!! I hated the fact that I haven't finished this up yet and now I'm on a mission! I'm back in my cozy little "shop"working on my favorite money pit. I'll have some pics shortly and bring everything back into my world. Stay tuned for more STUFF!
Offline kustombrad
« Reply #317 on: March 31, 2022, 07:27:56 PM »
Finally getting my front wheels cut out. Wasn't sure what "hardness" aluminum I was using until I had a nice talk with my machinist explaining everything. Onward ho...
« Reply #318 on: April 02, 2022, 01:13:51 AM »
Brad,
Remember that you have to accelerate the wheels to rotate and your present design is pretty massive and has a high polar moment of inertia which is what you have to accelerate. I think you "tread" design is pretty good as you have enough crown and side radius to help prevent to much salt "ploughying" when the wheels are turned but the rim thickness, the "web" between the rim and the bearing carrier and the area that the bearings are carried in are massive and certainly much more than is required. Any of the alloys that you have listed on your drawing will be more that strong enough for a wheel of this size, although the two 7500 series will probably cost you over double the cost of 6061-T6. I did a solid wheel design for a 21 inch dia wheel that would weight less than 1/2 of your present design and have it signed off by the SCTA tech inspectors.
On the other hand if you do happen to crash with these wheels you will probably be able to run them on your next car as they look indestructible!
« Reply #319 on: April 02, 2022, 10:22:22 AM »
Brad, if you haven't already acquired aluminum give me a PM... We have a large surplus aircraft aluminum Yard here.... even with shipping from Kansas it will be less than half of new price.  I can check to see if they have what you need.
« Reply #320 on: April 02, 2022, 11:58:17 AM »
Since we have such a good supply of LSR tires these days, why do you want to build a solid wheel??
« Reply #321 on: April 02, 2022, 09:15:24 PM »
Sid... 13 inches tall... even my little tires are bigger than that... everything you don't put in the air has 0 drag
« Reply #322 on: April 03, 2022, 01:30:44 AM »
I went back & scrolled through the pics & I see it was designed around front tires so why the change?
« Reply #323 on: April 03, 2022, 11:34:03 AM »
Like you Sid, I had to refresh the path of the rabbit hole... and reread a bunch of this to see where this project was going.  It looks to be designed for those little dragster wheels... so aluminum is a good way to go.
Brad... consult with a bearing guy if you have not already... about expected rpm and loads.
Back to work  :cheers:
Offline kustombrad
« Reply #324 on: April 19, 2022, 10:11:05 PM »
Rex, I definitely need to talk to you when you're not too busy. As far as surplus aluminum goes, I'm definitely game to find out more! Can I call you guys when you're not too busy? I'm doing aluminum front wheels because these mock-up tires I have are date coded 1989! Scary...
« Reply #325 on: April 21, 2022, 02:13:58 AM »
Back in the late 80 before the second generation Mickey's were available we were nocking on 400 with 1970's Firestone's. Some of the older guys might remember us giving the snapped cords a "haircut" & running them again. 8-)
Offline ronnieroadster
« Reply #326 on: April 21, 2022, 07:14:02 PM »
  Boy those were different times when men were men and sheep were scared    :cheers:
Offline racergeo
« Reply #327 on: April 21, 2022, 08:09:21 PM »
    First time ever at Bonneville I was watching in amazement as crew of Al Teagues streamliner painted black latex paint over the cords of there tires after cutting the straw along the rims off. they explained the tires were like 10 ply and no worries. Actually Poteet would probable run on the cords if they let him.
Offline kustombrad
« Reply #328 on: April 22, 2022, 12:43:47 AM »
I'm not running 30yr old tires no matter how many ply's...
Offline kustombrad
« Reply #329 on: April 22, 2022, 12:46:08 AM »
Was great talking to you today Rex! Thanks for the kind words, listening to me ramble and sharing some great advice!!
