Apart from less grip, (possible) surface roughness, corrosive properties, higher altitude, and one way runs .......... what does a normal Bonneville event offer to someone already at this high speed other than the name?
1. Knowing you averaged the speed over at least one mile (not through a trap).
2. Knowing you have a vehicle that will average that speed over that distance (takes a whole other motor/strategy to make something live that long vs. through a short trap).
3. Knowing you averaged the speed over 2 runs. And some years lately the runs have even been in the opposite direction if they are able to safely do that (sorry, but not in the same day unless you want to rent the salt)
4. Knowing you get to run wide open much longer
5. knowing all the other things you mentioned.
But Malcolm you already knew all of that.
This is not to take anything away from the 265 mph run over there. That is a phenomenal achievement and I'm very impressed
, just under a different environment.
c ya, Sum
