Some interested comments on this issue...
May be some will remember what I wrote before about car/streamliner design.
The rule, that's more important that a car goes properly out of the air (rearend) and less important how he goes into the air (frontend) counts also for a bike.
With a big different:
The drag of a bike is similar like a house....a moving house.
And the house got the better drag........
Alright - I can see now a lot of question marks....
As a example - if you take a block of brick's with the same outside dimensions of a crate of beer (20 bootles) in the windtunnel, you will find out that the brick's got the better aerodynamic with more cross section than the crate (space between the bottles).
The space between the bottles creates turbulences - turbulences means increase of the drag - or in other words - loosing speed.
A motorcycle is similar like the bottles - the open (or semi open) front wheel with the spoke - the front "suspension" fork - the aerodynamic covered engine - which got holes in to give the engine air - for radiator and carburator.....
Somewhere through and around all this "barriers" has the airflow to find there way.
So the frontend has to be cleaned up from barriers - by a motorcycle a clean frontend is more important as by a car - also a car has more length which can be used to smooth the created turbulence on the front.
A great solution is Fireman Jim's front wheel cover - I liked them when I saw the bike the first time at the salt.
The front of the turning wheel is covered, so there is a clean airflow - behind, the air can move clean around the "body", there is no wheel cover from where the airflow has to escape. If he got the front open and the rear of the wheel covered (normal standard wheel cover) the air has to escape forward - against the airflow - and downwards.
Jim's solution eliminate this problem.
But also for the motorcycle it's important that the rearend is clean - so that the air can rip off clean behind the bike.
Without a clean rear end the air collapse behind the bike, creates a vaccum and turbulences - and also it's affect the handling of the bike - the
bike goes not proper straight - feels weak on the rear wheel.
One of the big mistakes I saw over the last years - on this new modern aeropack body parts - Jon Wennerberg, John Noonan and also the Amo brothers using so big rear wheel fender, which goes closed deep down behind the rear wheel.
Under this rear fender the air builds up an air cushion, which likes to go out of this "closed" space - the only chance to escape is downwards, directly into the airflow along the bike and rider - this produces a lot of turbulences.
If the back part of the rear fender got some slots in, the air could escape through this slots and has not to run into above airflow.
In other words, this fender works like a airbrake......
Summary:
A bike has to go clean out of the air, so as a car, but also the frontend has to be free from turbulence creater, due to this that a bike got not the length to smooth the airflow, before the airflow reach the rearend.
This as a short explanation.
See ya
