Sum, why do you need a second battery for the LM1? Are you getting too much noise from the main battery? Just curious, I'm running a LM1 also.
The car is running a mag, which did give us a lot of problems last year as we weren't running suppressor wires. Now that seems to be ok. There is no charging system on the car, so it is running total loss. The main drag on the battery other than the starter starting the car is the elect. water pump.
I just want to make sure the LM-1 and Aux-box are getting a good clean 12 volts. Last year we had just the LM-1 and it recorded fine, but you have to make sure you remember to push the "record" button after the car is started since it can reset during the low voltage at cranking. The other thing is if we got to the line and had a hard time starting and ran the battery down, but got started the LM-1 might not be getting 12 volts during the run. I don't think the water pump cares.
It is just a little more insurance. So few runs. So much money invested. Want to make sure we collect the data we now are able to collect with the LM-1 (air/fuel) and the Aux-box (rpm, boost, egt, TPS, acceleration) and not take a chance on not collecting it.
Hooley is paying me "BIG MONEY" to worry about this stuff
Are you running an aux-box or rpm?
c ya, Sum
