Author Topic: TFA Racing Lakester "tweak" diary  (Read 98520 times)
Offline pasodude
Re: TFA Racing Lakester "tweak" diary
« Reply #15 on: April 29, 2014, 09:23:31 AM »
Sound good karl ! Speedweek? I'll be bub's motorcycle speed trails for sure ,love to cheer you guys on& ckeck on the new hot rod !
« Reply #16 on: April 29, 2014, 11:21:00 AM »
Looks great Karl & Don. That new windscreen looks swanky, is it cracked?
3 months to go, yikes!
Dean
Offline entropy
« Reply #17 on: April 29, 2014, 02:49:03 PM »
Dean
Thanks, dean!
I am sure you are joking about the crack, yes? :cheers:
karl
« Reply #18 on: April 29, 2014, 03:09:42 PM »
I'm not, but I guess it's just the rippling of a protective film. Shape looks better to my novice eye.
Here's greenie as of this weekend, hopefully start wiring the Motec soon.
« Last Edit: April 29, 2014, 03:12:14 PM by sabat »
Offline entropy
« Reply #19 on: April 29, 2014, 03:49:05 PM »
Dean,
I REALLY like seeing bars ahead of the fork tubes on greenie, puts yr arms in a much better position.  When are you gonna run it?  where?
On Lexan cracking, i'm no expert but i gotta tell you it is a world better to play with than plexiglass.  It seems to have mechanical properties more like a soft metal than plastic.  It can be bent like crazy and drilled like aluminum,  although it apparently takes heat to bend it permanently. It doesn't seem to easily crack. (i'll probably eat those words).  As you note, the "cracks" are the protective film.
« Reply #20 on: April 29, 2014, 04:21:59 PM »
Thanks, more comfy than chicken-wing posture too. The plan is Speed Week, but I've got a lot to do. That's your plan with Don, right? Shakedown meet with modest engine?
Offline entropy
« Reply #21 on: April 29, 2014, 05:03:49 PM »
Excellent, see you at Speedweek if all is settled down at Casa Sabatinelli.
Yup, you have our Plan exactly right.
1. see if it goes straight
2. learn to consistently pull the HS parachute and not the engine bay fire bottle
« Reply #22 on: April 29, 2014, 06:56:19 PM »
Dean:
If you've told us about your new bike project I missed it.  So - how 'bout telling us about your new bike project?  Thanks.
« Reply #23 on: April 29, 2014, 07:29:49 PM »
Great up date. I enjoyed this build the first time. It will be great to see the lakester run in its new configuration.
Thanks for the tweak diary
« Reply #24 on: April 30, 2014, 12:37:24 AM »
Very nice new chapter guys!
Offline RansomT
« Reply #25 on: April 30, 2014, 09:49:00 AM »
Motec on an NA bike?
« Reply #26 on: May 03, 2014, 08:18:13 AM »
Sorry to divert the thread, I PMd Jon and Ransom about the bike.
Karl / Don, are the wheels, chassis lengthening and windscreen the major changes? Anything else planned before its debut? Will it be painted green? :)
Dean
Offline entropy
« Reply #27 on: May 03, 2014, 09:49:00 AM »
Dean
Dean there are a few other things besides chassis +22", custom zero scrub wheels, and new design canopy/windshield...
- new latching, hinges & locking supports for canopy
- skin replaced as necessary to improve engine access
- new air scoop
- new rear axle, moved 13.5" rear, added adjustable height & F-B (help weight distribution)
- lateral hand protection bars added
- leg belt added
- new customized seat and all seatbelt anchors replaced, seat belts upgraded
- cabin cladding to protect driver from chassis tubes
- steering wheel & linkage replaced
- transmission ratcheting shiftgate added
- throttle and brake pedals replaced
- exhaust headers replaced
- waterpump, replaced electric with mechanical, de-pressure watertank
- electrical switch/fuse block replaced
- add complete Racepak digital dash & data recording system, F&B facing vid cameras
- front hubs replaced with new units
- new rear brake calipers and pads, master cylinder relocated
- firewall replaced, added 2 x 2" Lexan viewing ports
- 2 lateral helmet restraint plates, custom padded, added
- cabin tubes padded around helmet.
- helmet forced air system installed
- will add lead ballast to nose to get 55/45% or more F/B weight distribution
- powder coat chassis white
- paint car dark metallic blue with white belly
Don is being a very busy boy!
Karl
« Last Edit: May 03, 2014, 09:53:16 AM by entropy »
Offline entropy
« Reply #28 on: May 03, 2014, 10:16:58 AM »
just a postscipt here.
Some may notice that no hp issues are addressed.
we have a 2014 plan as follows:
2014 Objectives:
   1. Build/modify a good looking Lakester with no compromises on safety, handling, reliability, driver ergonomics, data monitoring.
   2. Don & Karl get solid experience in each personally driving a 200mph parachute car at Bonneville.
   3. TFA Racing Team develop & implement robust operational procedures & checklists
   4. Develop accurate predictions of #5448's "mph vs hp" potential      (chassis dyno + actual Bonneville speeds + wind tunnel)
   5. D&K make informed decision for 2015 season:
        - make our TFA Racing Lakester faster, or
        - make our TFA Racing Lakester slower, go for record
        - make "minor" improvements and run it for "cheap" fun
        - sell the car and take up fishing
« Reply #29 on: May 03, 2014, 10:29:48 AM »
2014 Objectives:
Sounds like a great plan and a more realistic one than I often read  :-),
« Last Edit: May 04, 2014, 01:30:47 AM by Sumner »
