Author Topic: Springfield Flyer.  (Read 1459745 times)
Offline Buickguy3
Re: Springfield Flyer.
« Reply #525 on: April 01, 2014, 10:18:44 PM »
   Mike,
   I've got an Oxy/Acety. setup that I haven't used in years. Now you've given me some new ideas. I wonder how far I can make that rabbit in the garden fly? With the right trajectory I'll bet I can hit the neighbor's house. It's only 1/4 mile away. This should be fun. I could put a video camera on the IED and film the firing.
                   [America]
« Reply #526 on: April 01, 2014, 10:26:02 PM »
We used to call those baloons Megaloons. 40 years ago one of them launched my nephew across the yard. He's getting better.  :wink: Wayno
« Reply #527 on: April 02, 2014, 02:30:42 PM »
I should have kept my mouth shut (not written) about that mole. :-D :-D
« Reply #528 on: April 02, 2014, 05:06:14 PM »
Just your crazy buds trying to help  :-D  :cheers:
Offline Frankie7799
« Reply #529 on: April 02, 2014, 05:24:02 PM »
Yeah what Stainless said  :-D :evil: :cheers:
« Reply #530 on: April 03, 2014, 06:24:04 AM »
The cool thing is that I get get to share stuff with guys as nuts as I am. :evil:
It's all good and I can imagine the Dodge you guys got up to as kids.
You had TV and I didn't. No excuses guys. :-D :-D :-D
Got to making mounting plates for the pneumatic lifts.
Did all four by clamping together 10mm plates. Hole sawing took hours on the Beijing drill press and drilled the four holes that magically lined up with the component's threads.
I've got one fried on and used the sample to see what it looks like.
« Reply #531 on: April 03, 2014, 06:27:13 AM »
Prepped and cleaned all surfaces.
Tacked the two plates in sit u.
Tigged them on the table. Both sides because getting to the underside will be tough later.
« Reply #532 on: April 03, 2014, 06:30:17 AM »
Set the mounting up correctly making sure I left enough space to slide the 2mm plate that will be part of the box section and also checked that when I do eventually fit the actual lifts they clear the frame rails.
After that I welded the plate in place.
« Reply #533 on: April 03, 2014, 06:32:57 AM »
The trick is to get both lifts on the same plane because we'll be bolting a plate (that will act as a foot) to the ends of the pistons.
Came out sweet IMO.
3 to go. :cheers:
« Reply #534 on: April 03, 2014, 07:02:44 AM »
Just a hint Mike. If you activate them with nitrogen rather than compressed air right from the start you'll keep moisture out of the system. With the stock cars and Indy cars we used nitrogen in place of compressed air for everything. It makes life pretty simple and is readily available from your welding supplier relatively inexpensively.
« Reply #535 on: April 03, 2014, 07:49:29 AM »
Thanks Pete.
Silly me. I wanted to use CO2 but Festo said it destroys the seals so we were going to go with compressed air.
Now I know better. Imagine the H2O in that. :roll:
You're a big help. I appreciate the heads up. :cheers: :cheers:
Offline Speed Limit 1000
« Reply #536 on: April 03, 2014, 12:05:10 PM »
Do you have a plan to make something so you can lock them in the extended position?
« Reply #537 on: April 03, 2014, 12:21:23 PM »
Festo are giving us hand operated valves for that.
That's what they said.
I'm getting all of the stuff next week.
The lifts are a custom length so they have to build them.
« Reply #538 on: April 03, 2014, 09:20:09 PM »
Here's what the two front mounts look like.
« Reply #539 on: April 03, 2014, 09:22:49 PM »
Rears are done too.
The plate I used to fabricate them was a little pitted on one side but I polished the heck out of the parts after cutting and drilling.
