Author Topic: Springfield Flyer.  (Read 1459555 times)
Re: Springfield Flyer.
« Reply #1305 on: January 23, 2015, 05:35:03 AM »
The neat thing is that the system is height adjustable and
when the tank is fitted there is no interference with any
of the parts nearby.
« Reply #1306 on: January 23, 2015, 05:36:32 AM »
One more view.
I can hopefully finish the work on the tank this weekend.
« Reply #1307 on: January 23, 2015, 08:00:20 AM »
« Reply #1308 on: January 23, 2015, 08:30:12 AM »
Nice job of packaging Mike.  :cheers: :cheers: :cheers:
Don't forget to put something to keep the tank from sliding down when vibration inevitably causes the clamp to loosen.
« Reply #1309 on: January 23, 2015, 08:49:35 AM »
Hi Sparky, I'm still waiting to hear from my friend on the ratios
and I'll let you when I do. :cheers:
Will do Pete, thanks man. :cheers:
« Reply #1310 on: January 23, 2015, 10:11:06 AM »
still looking--- have two leads no one has committed or asked for payment!!
Online floydjer
« Reply #1311 on: January 23, 2015, 10:15:20 AM »
From one "One Man Band' to another..Looks great Mike. :cheers:
« Reply #1312 on: January 23, 2015, 08:23:57 PM »
Thank you so much for helping Sparky.
I've got a set waiting for me. :cheers:
Thanks Jerry, I'm still waiting to get a glimpse of your project. You're a dark horse!!!!. 8-)
« Reply #1313 on: January 26, 2015, 02:26:46 PM »
The health is taking strain here.
The epoxy got to me again so I have to lay off it for a while.
It is what it is so I moved to metal for now.
To anyone that has never built a liner, don't kid yourself that packaging is a snap. :evil:
Trying to find a spot for the oil tank wasn't easy.
I wanted it centered on the water tank in front of the motor.
If the big a$$ fire suppression system wasn't already going there it would have been fine.
I eventually settled on having the tank against the right side frame rails and in front of
the motor mount plate.
It needed a plate welded in to attach the tank mounts to.
That's as far as I got. Some pics. :cheers:
« Reply #1314 on: January 26, 2015, 02:29:43 PM »
I wedged in the Carbon tank mounts but they'll need trimming
to fit the way I want.
The advantage is that where the tank will sit it will be easy to remove
the filler and lines will be fairly short.
« Reply #1315 on: January 27, 2015, 08:51:28 AM »
Mocked up the oil tank today.
I have clearance everywhere. :-D
I had to notch one of the chassis brace supports.
« Reply #1316 on: January 27, 2015, 08:53:18 AM »
I found an old water pump pulley and used that as a sample.
I have a few inches gap which is good.
« Reply #1317 on: January 27, 2015, 08:56:45 AM »
There are two mounts and hose clamps to hold the tank
but the bottom one still needs slots cut so I just used the top one.
There is enough space at bottom for the -16 90* fitting so it looks alright so far.
Another sleepless night averted. :evil:
« Reply #1318 on: January 27, 2015, 12:47:05 PM »
isn't packaging a "special construction" fun
« Reply #1319 on: January 27, 2015, 02:07:57 PM »
Thanks Sparky!!!! :-D
Fun it is if you like pressure.
One thing you learn is that you're always thinking ten steps ahead.
I haven't had to remove any welded parts in a while now so I must
be learning something. :wink:
