Thanks all.
Sid, I'm going to have to add extra braces but it won't be easy.
I was dumb enough to angle the female fittings on the cage side.
If you make the two braces a fixed unit you won't get them unbolted.
Brackets, bolts and head scratching coming up.
The body profile doesn't quite follow the bars but I had to get them
out of the way towards the rear. The shape of the car is pretty similar
to Danny Thompson's in that area so I emailed him and asked if his flush mounted
inlets worked. He told me at the time that he hoped so but only testing would
prove it. After he ran way over 300 the report was that the inlets were fine.
Good enough for me.
I was lucky enough to land a sponsorship from a company called Marcom Aeronautics and Space,
a local company that is building launch vehicles for satellites and they're doing all the CFD.
Mark has finished the solid model and says it's much smoother now but the "meshing" takes time
and is the difficult bit. Once that's done I can finalize the body shape.
It takes a lot of very clever people to build a long car and I've been blessed with so many.
You won't get this sort of help in any other form of motorsport, that I can guarantee.
