Way to go, Tim! Getting through the traps wide open with everything pointed the right direction is a real accomplishment. Running with no rear suspension seems to work for many as long as the course is fairly decent. When it gets rough or really loosened up you may find you want at least a little rear suspension, especially in a short wheelbase car.
Your weight distribution may be biased to the rear a little too much. It looks like adding the weight definitely helped the traction situation. If you end up having directional stability trouble, you might consider putting some weight over the front axle. Remember the dart theory - CG ahead of CD.
Good luck and keep having fun.
