Off we go on another possible thread, Sumner. You mention lakester and "up in the air". I have been searching for a few years for the (a?) definitive answer on what is the optimum cross section for a liner. Now Jack Costella has done quite well with cars that have probably less than 1" or ground clearance. But the really top dogs, Nish, Burkland, Vesco, White, Teague all have their cars up in the air some like your lakester.
A number of years ago when I first though about building a car Jack convinced me to build the car with suspension. Of course those were the years in the 90's when the track was really getting bad and Jack couldn't always run, since his head was getting beat around so much he lost vision. Now someone has told me Jack would try and talk me out of suspension and his recent car (5050) has reinforced that. I would love to see what he is doing with the lakester he is suppose to be building. I'm betting it will break with all current tradition
. Haven't had a chance to talk to him about that. Sure wish he would post on here as he is a wealth of information. Except for last year the salt has been pretty smooth and suspension/no suspension has been pretty much a non-issue. Unfortunately I believe if the BLM lets the current Potash operation continue, regardless of the salt put back, the salt will eventually deteriorate again and then there could be years like last year regardless. After waiting all year to run and the expenses involved make me want to try and design a car that can run under as varied conditions as I can anticipate.
Additionally there is the subject of cross winds and the need to be aerodynamic cross wind wise, if you will. It would seem that a Nish type cross section with highly rounded sides would be the least reactive to the winds.
But then I've seen the videos of Nish's airborne maneuver, and it wasn't pretty either, ......Jim
I'm finally going to get to your
"definitive answer on what is the optimum cross section for a liner" comment. If I wasn't running suspension I would want the car flat on the ground like Jack has done and what it looks like you have done (I don't have any pictures of your car
). Keep the air out from under the car and just deal with what is going down the top and sides. I would want the car to have rounded corners in the front and flat square corners in the rear. This would help keep the center of pressure at the back of the car even if both ends had about the same height. Since the center of pressure is effected by the side view of the car you can look at the Cd of the side view. Let's say the car is a perfect rectangular shape from the side with the height the same front to back. Since the front would have more rounded corners it's Cd from the side would be lower than the back with it's flat sharp cornered sides, which would be worst case "like a brick/flat plate" with a high Cd. So in this case the center of pressure would be rear of the center of the rectangle even though the side view would indicate that the center of pressure would be in the center of the rectangle. Hope this makes some sense. Also this is my feeling on the subject, based on my thoughts and also conversations with others. I welcome any other views.
.........But then I've seen the videos of Nish's airborne maneuver, and it wasn't pretty either, ......Jim
I guess nothing is going to save your a** in every situation
Since I want to run suspension I'll have air going under the car and just can't get around that. So after reading the "Leading Edge" and some other material it seem like the minimum height for a body to be above the ground and get away from the effects of bad aero from air going under the car is about 6 inches. More is better, but with diminishing results. The other thing that helps is to have the bottom curved (in cross section) to avoid air being trapped under the body as it can bleed away, and I'll do that. So I agree with your...
My belief is it's important to "bleed" the boundary layer off rather than have it build to compression at some point under the car. Therefore it would seem that a rounded bottom, even a pointed boat shaped bottom might be the best. ............
...............I find from experience that my square car has been rock stable in all but the most heavy crosswinds, literally being a "one hander" even in the plowed field that El Mirage became in the final few runs in June............
If it works, why change it then
.........So who knows?...........Jim
Not me
