I have been a proponent of "lead down force" for a long time as aero down force can be a bigger component of drag than the car itself at high speeds. Aero down force is not free, every aero device that generates lift. or down force in our case, has some level of drag and both the lift and the amount of drag are a cubic function, i.e. if you double the speed you will have 8 times as much down force and 8 times as much drag. My views on using aero for down force are being modified when it comes to cars that are trying to go 400+ in the 5 mile limitation of the Bonneville race course. For these cars it is as much drag race as it is top speed through the 5 mile traps. Many of the 400+ cars have never been able to use all of their power simply because they will spin the tires at almost any speed. One potential solution is to have a light car with big horse power and a method of developing large amounts of aero down force at fairly low speeds and then be able to maintain that same level of down force, and drag, by manipulating the aero surfaces during the run. There is one car that is presently pursuing this approach and it may be at the salt next month so watch for the NACA 66 car from Rob Freyvogel they might just suprise a lot of people.
