It seems to me that if you have an S&S "Harley" that has been dumped from M into A, you guys should be laughing.
Why? Because a solid "M" record is being converted into a soft "A" record? No thanks, I'd rather have a good record than a soft one. To set a strong "A" record, I have to build a new bike.
BTW, that 167mph M-PG record you mentioned ... we ran that bike in '03 in the fuel class, on gasoline, and ran 166.9 and set a soft record. I got the bike home and discovered we had cracked the cases, from one cylinder stud down to the timing plug and back up to another cylinder stud. I replaced them, and we went out in '04 and ran against the gas record. We literally made only 2 passes on it, a qualifying pass and a backup pass, and set the 167 record you mention. After the backup pass we noticed a crack in that exact same spot.
The following year (last year), we wanted to bump up the soft fuel class record we had set in '03, by adding some nitrous. Obviously the cases weren't going to hold the additional power, they weren't even holding the power we were making on gasoline. So last summer I did the logical thing, I shelled out a couple grand for a set of S&S cases. Got it all together, tuned perfectly, ready to go obliterate our old record, and the events were all rained out.
Next thing I hear, S&S cases won't be allowed in "M" anymore.
Well Fiat me, thanks a bunch for the advance warning on that!
This is a Buell S1, a short, tall bike. There ain't no way in hell I'm going to get this chassis to the 199mph A-PG record. By my calculations, as it sits it'd need in excess of 230hp to do that. I know how to make 230hp, but a 1350cc Harley motor becomes an expensive, high maintenance deal at that level. The only realistic thing to do is to make a lay down bike out of it. New chassis.
So the bottom line is that they obsoleted the bike before I got to race it. It's now a Bub's-event only bike, unless and until I do a new chassis. I'm sure you can understand how I'm a little reluctant to go spend thousands more to do that, given the way this sanctioning body makes rule changes.
They need some kind of a review and comment period if they're going to make radical class changes like this. They costed me a big pile of money and time.
