Until you have rpm and fuel pressure I don't think you will find the solution.. You never did say what rate of change in rpm was programmed on the dyno as well. It might be a matter of changing pump drive ratios and nozzle sizes along with the usual secondary bypass drill of springs and jet sizes under boost.
Dave
The dyno was so screwed up we didn't really get enough of a base line to figure much out and Hooley wasn't able to look at the graphs (above) until he got home. We only have one graph from them and it was the second lower boost run as the first run kicked off their computer.
I looked at our graph and theirs for the second run and during the period of low boost the rpm went from 3700 to 5800 in 10 sec. We are not setup at the moment to data log fuel pressure. That might be a good thing for us to think about. There is still one input (we could disable the acceleration) that we could use for that. We didn't think of that, thanks.
If we have time/money before August Hooley would like to go back to a better dyno in Tulsa that has more experience with race motors. Looking over everything, we need to work on the secondary circuit like you said. We do have different springs/shims to do that.
We will have RPM and better TPS readings at that point. The TPS readings along with flowing the barrel valve (in the shop with air) should help us to know in the future if we are on the barrel valve or only on the pill at different throttle settings.
The plan before the next run is to try and richen the secondary and pill for safety and also change the pulleys and lower the boost. I feel we need to get the air/fuel in the low 12's maximum under boost and see if we can get the EGT to level off as on the other two runs it was still climbing at the end of the short pulls.
So are you saying we can change the drive ratios of the 80A pump also??
What kind of parameters are we looking for with the fuel pressure if we can log that??
Thanks and c ya,
