Javier. Could I also use this to reset the switch or would this be a one way only thing?
Quote from: Tman on February 21, 2013, 02:25:35 PMQuote from: jdeleon on February 21, 2013, 02:10:35 PMRob,How about welding a tab down off a hartwell latch.I was thinking of this at my desk, I am going to play with the idea when I get home tonight.Tman, did you come up with anything?I was thinking of fabbing a 1.5 wide x 8" long flat rocker rocker switch that would sit flush when switch is in the on position. Maybe I can make the handle part itself extra thick (maybe 3/8" aluminum) so that it can stick up above the body work a bit then be contoured to match the body within a few thou using a flap wheel.
