Author Topic: Belly tank diameter question  (Read 23175 times)
Offline hotrodderhaag
« on: January 15, 2013, 09:20:10 PM »
I found an original aluminum belly tank that can be bought at a reasonable price. .. It is 23" diameter . Is that too small? I was gonna run a ford flathead v8. Please let me know your thoughts and opinions
Re: Belly tank diameter question
« Reply #1 on: January 15, 2013, 10:06:05 PM »
Start by planning a layout.... do you have a Flathead to work with?  23 is fairly small, so my opinion is it is probably perfect... how long?  Don't forget you can make it an oval if you need width.
Offline Jack Gifford
« Reply #2 on: January 16, 2013, 01:03:49 AM »
... Don't forget you can make it an oval if you need width...
Almost anything can be done with the body for a special-construction category vehicle; just sayin'.
I suggest you study photos of old-time small-tank lakesters, especially those that had flatheads- either sixty-horse or "full size" V8 engines.
M/T Pontiac hemi guru
Offline DND
« Reply #3 on: January 16, 2013, 05:07:51 AM »
It also depends on how you want to set in the tank, all inside like Markley did or have your head out in the wind or maybe a canopy on top?
« Reply #4 on: January 16, 2013, 06:38:41 AM »
guys,
i have a 1937 21 stud for flathead v-8, trans, and rear end all running ready to go, compleley rebuilt....  id rather have my head out of it with a canopy i belive. the dimenssions of the tank i found are 23"dia x 14.5 feet long... its aluminum.   im buying the tank just cause its a good deal. and i would like to use it, but i almos thought about a fibergalss P38..... this will be my first belly tank build ever so i want it to go somewhat smooth. i know im squeezing ten lbs of shit in a five pound bag, but it gonna happen
« Reply #5 on: January 16, 2013, 07:42:33 AM »
Use the one you've found as a cowl..buy a 38 in glass, then you've got a cool lookin tank...
« Reply #6 on: January 16, 2013, 08:26:27 AM »
anyone have some good belly tank pictures> p38 style. i googled some.
Offline dw230
« Reply #7 on: January 16, 2013, 11:20:45 AM »
Take a look at the American Hot Rod Foundation site, www.ahrf.com, they have a photo library beyond compare. Contact Jim Miller on that site, he can help locate hat you are looking for.
« Reply #8 on: January 17, 2013, 01:09:13 AM »
My lakester (pictured in my avatar) uses a fiberglas P-38 replica tank made by ClassGlass in Maryland. It's 36" diameter and 150-some inches long.
« Reply #9 on: January 17, 2013, 01:18:12 AM »
24 inches is plenty small.  I am not a real big guy at 5'-11 inches and my shoulders are wider than 22 inches with my leathers on.  That's less than an inch clearance on each side at the middle of the tank..   No way I could fit.  You will need some room to fidget.
Offline DND
« Reply #10 on: January 17, 2013, 05:22:19 AM »
Plus the frame - roll hoops -padding etc, you would have to be a Tenny-Bopper to even get in the thing !!
« Reply #11 on: January 17, 2013, 06:42:17 AM »
im affraid you guys are correct. i think im gonna go ahead and build one with the p38 tank out of glass........... so that being said. where is the best place to get a  QUALITY fibergalss tank.?
Offline Captthundarr
  • In line
« Reply #12 on: January 17, 2013, 08:15:33 AM »
Try this fellow, he might be able to help. http://p38-droptank.com/P38-Drop_Tank.html
Elmo Rodge is on the forum.
Offline dw230
« Reply #13 on: January 17, 2013, 11:36:25 AM »
Elmo's tanks are off the forms developed by the late Jack Kelly. Jack's tank, NOT tanker  :x, is the beautiful, yellow #64. The car has been in storage since Jack's passing. There are plans to move it to White Goose Bar World Headquarters for a refurbishing by the craftsmen on that team.
There may be beer involved.
« Reply #14 on: January 17, 2013, 12:54:41 PM »
youll never hear me say TANKER... not intentionally anyways.
well i did some research.. found this company.
http://www.gothamcruisers.com/index.htm
they make a p38 tank with head rest for $1100.
and its nice looking,
they are using this companies tank in the build below:
http://www.jalopyjournal.com/forum/showthread.php?t=763913
and so far they are reslly happy with it from what im told.... other companys are at 1250 or higher for a glass p38 tank... and the gotham cruisers are about 4 hours from me, so i think i may order one from them and maybe take a tour of the place. from what i see and how they talk, they are  good at what they do.
« Last Edit: January 17, 2013, 01:02:03 PM by hotrodderhaag »
