Clean tubing really helps. I really like the better 1 5/8 DOM that comes with the dacradized finish (nice gray color when you get it). I try to keep the inner weld line about 45 degrees inward from the vertical line of my bend. Metal compresses easier than it stretches. I really dont like putting that weld line on the very outside or inside of my bends.
I do a lot of 10" mark-to-measure for my positioning and bend checking. For example, lets say I'm going to bend a simple roll bar with two 90s. When I get tensioned and set in the die, before starting the actual bend, I make a good mark exactly 10" from the back edge of the shoe (straight part of the two dies). You must hold tension on the tube, to keep it fully seated while you measure and mark.
After you make the bend, keep tensioned and measure how much tube you actually drew. I like to turn the tube around and draw the first bend toward the new bend. Because I know how much tube length I drew, and the overall width of my bend, I can position the tube to get the new bend outside radius at the width I was targeting. Heres the catch: you need to do a pair of bends on a spare piece to determine the exact amount draw-to-bend difference for your tube. Some stretches the outside, some squeezes the inside. Even using care, I often miss my target by 1/16-1/8". You'll see quickly how much tube length to add to hit your targets.
Regarding bend angle, it is easier to unspring a little over bend than to go back in and add more bend. Never try to unspring in the bender, it breaks the pin ear right off the shoe.
. My bender table is made out of heavy wall square steel tubing with a solid 3/16 top plate. It bolts solid to the floor, and I can clamp onto it anywhere to unspring a bend....just not on the bender itself!
I know there are folks here that can give you a better method, and my apologies if I'm "preaching to the choir". This works for me, having bent five car cages and more bike frames than I am willing to admit in public. This unfinished project (not mine) is one I did bends for. I did hit that main hoop width on the first try.
http://www.landracing.com/forum/index.php/topic,5416.0.htmlI hope you have as much fun with your bender as I do with mine!
Regards, JimL
