IMO...
As a professional gear crasher, I can say that LSR doesn't load the gears like other racing does.
I can shatter a Ford 9" on the start line drag racing. Too much weight, too much torque.
However, it wasn't phased at 7100lb at 200mph on salt. I'd never run it on pavement though. That gets an 11.5 axle that can't be broken by mortals.
IRS's aren't always weak. The Getrag units will absorb a huge amount of abuse. I twisted 1/2 shafts without hurting the IRS before an idiot decided that a 7200 rpm launch on the last day of Carlsbad would put on a good show. I moved about 6" and pieces bounced off the back wall. Not sure about the Ford piece, but I was impressed with the late GM unit.
Load it up on a dyno at the target speed, then pull the engine down. If it's going break, it will do it on the dyno. Use a infrared therm to check case temp. More than 180 could be problems.
