I've watched this thread and kept quite, but decided to now weigh in.
First, about the 'spec' style class proposed by Wobblywalrus- Seriously?
Bobby, while I liked your initial proposal, I doubt it would fly. I think that EVEN if you got it started, there would always be those trying to get it changed, probably going down the same path it is now! To me, the club idea sounds very doable!
Pedro, I follow the Montana Boys's exploits with awe and admiration! You guys have done a helluva job getting those old Dodge 4 bangers moving!
Having said that, however, I have to say that I'm in favor of the rule change, so that electronics are kept out of the vintage class, and the playing field is level.
I know that this will negatively impact some of the cars out there, but I think that if a guy can get these old mills moving down the salt, he can change ignitions.
When I started the build, I figured I'd run a boost referenced MSDbox- after all, the rules said any ignition. I was diligent about running almost all of my build ideas through the tech deptartment, because I was new, and didn't want issues on the salt.
I was told absolutely no way! Ok, they didn't word it like that, but said no. We run a simple magneto now.
At Bonneville this year, I was careful to look at the other vintage setups VERY carefully, especially in impound. Guess what? The playing field is NOT level! Cars set records, and made it through impound with MSD boxes, boost referenced MSD boxes, etc!
So, either we need everyone to be able to run this stuff in vintage, or no one. I vote no one
Good luck with that Dodge. Garry and Craig said you had figured out some issues with the head, so I'll be watching you set new records next year, I'm betting!
