SUMMER, TYPICAL OF GUYS YOU HAVE A LONG HAUL TO THE SALT GAY ONLY GOT ONE RUN AT BONNEVILLE LAST YEAR. THE NEW MOTOR CONF. IS A EARLY FORD 4CLY. FLAT HEAD WITH A NEW FORD TRITON 3 VALVE CYLINDER HEAD AND A SUPER CHARGER OFF OF A FORD LIGHTING TRUCK.THE PROBLEM WAS THAT GAY DECIDED TO INJECT THE GAS A HEAD OF THE SUPER CHARGER. BEING DRIVEN WITH A FACTORY STYLE SERPENT BELT AT THE HIGHER RPM THE BLOWER BECAME TO EFFICIENT WITH THE GAS AND THE DRIVE BELT COULD NOT HOLD UP. WORKED FINE IN THE DRIVEWAY NOT AT SPEED.THEY WENT THROUGH TWO BELTS ON SAT/SUN WENT TO SALT LAKE ON MONDAY FOR BELTS,WHILE OTHERS STARED TO MOVE THE INJECTORS DOWN STREAM OF THE BLOWER.........THEN RAIN
YOU HAVE TO LOVE MOTHER NATURE THAY SHOULD RETURN IN ,07 TO TRY AGAIN. THANKS ERIC
